I need to create a New Material in Robot that has a valure for Young Modulus of 3,8Kn/m².
But Robots accepts only MPa units for that value. So I write 0.0038MPA, but it automatically changes it in "0.00" because the value it's too low.
Any ideas?
Where am I failing?
Thanks!
Solved by Artur.Kosakowski. Go to Solution.
You can either increase the precison of the display or change the usints
