Discussion Groups
Robot Structural Analysis
Active Contributor
antoine.carimalo
Analysis report
257 Views, 4 Replies
11-21-2012 10:40 AM
Hi I am looking for the analysis report. Does it really exist?
When I use the "gestionaire des calculs" the report is generated automaticly.
Where can I found it if I run calculation inside my model?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Analysis report
11-21-2012 11:30 PM in reply to: antoine.carimalo
Try Analysis > Calculations report commands.
Artur Kosakowski
Active Contributor
antoine.carimalo
Re: Analysis report
11-22-2012 07:26 AM in reply to: antoine.carimalo
I have the french version so the option is accessible from "Analys" --> " note de calcul ".
But the note de calcul doesn't indicate calculation errors or warnings like "instability" "non convergence".
I would find a file or other that includes all the errors and warnings. Is it possible if I don't use external calculation with "gestionnaire des calculs" ?
No idea?
Product Support
Artur.Kosakowski
Re: Analysis report
11-22-2012 07:48 AM in reply to: antoine.carimalo
Please check: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Log-of-analysis-errors/m-p/3505326/
Artur Kosakowski
Active Contributor
antoine.carimalo
Re: Analysis report
11-23-2012 07:51 AM in reply to: Artur.Kosakowski
Exactly what I need once again. Thank you very much
