Missing combination codes.
Hello, whenever I try to create a new combination code they no longer appear in the checkbox.
(It doesn't matter if I save it on
C: \ Users \% username% \ AppData \ Roaming \ Autodesk \ Autodesk Robot Structural Analysis Professional 201x \ CfgUsr \ or in C: \ ProgramData \ Autodesk \ Structural \ Common Data \ 201x \ Rgl \
the result is the same) https://forums.autodesk.com/t5/robot-structural-analysis-forum/configuration-of-code-list-missing-load-combination-files/td-p/8592207 In did, this article helped the codes to reappear, but I still can't create new rules for the combinations. Can someone help me?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
It is caused by too many RGL files defined in both
and
Number of default and user defined combination regulations (.RGL files) exceeds 128.
Delete few not used RGL files from above folders.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
Yeap. It was the problem. Thank you very much
