Revit Structure
Valued Mentor
AJA14
Message 1 of 5 (169 Views)
Accepted Solution
wall detail level
169 Views, 4 Replies
10-14-2012 10:00 AM
Hi there. When I draw a wall with mtl studs in a structural template, i can't see the details even when switching to medium or fine level and change the discipline to architectural. But if I draw my wall in an architectural template, I can see the wall layers when switching to medium or fine even when I switch my discipline to structural. Any ideas.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Active Contributor
Message 2 of 5 (154 Views)
Re: wall detail level
10-15-2012 12:49 AM in reply to: AJA14
Is the wall in your structural template exactly the same one as in your structural family ?
Valued Mentor
AJA14
Message 3 of 5 (150 Views)
10-15-2012 04:25 AM in reply to: 5kings
Yes. If i draw it in the architectural template I can see the details when switching to medium or fine detail. but in a structural template I can't regardless of what I do (even when changing the discipline to the structural). I think it has to do with visibility settings of the structural templates. Any ideas.
Ali Al-Hammoud
Active Contributor
Message 4 of 5 (146 Views)
10-15-2012 05:36 AM in reply to: AJA14
Can you show me the type properties of the wall? Or group 1 wall, and save the group as an rvt. send me the files and I'll check it out.
Employee
Joe.Charpentier
Message 5 of 5 (137 Views)
10-15-2012 08:47 AM in reply to: AJA14
Is your view cutting the wall?
You will not see layers of a wall unless it intersects the cut plane of the view (plan or section).
In an architectural template, the default wall draws from the level up, and the cut plane is at 4'-0" or so above the level, and the view depth is limted to the level.
In a structural template walls draw from the level down,  the cut plane is about a foot above the level and extends below the level so you can see what is "supporting" the level.
Joe
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
