When you edit the family use text to place brackets. In view Properties
under annotation check to show in this view otherwise you won't see where
you are putting them. You could make 3 different tags.
bob v
wrote in message news:5542400@discussion.autodesk.com...
Is there a way for me to modify the studs and camber tags so that it will
include the bracket for the studs and show parentheses on the camber?
