Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Use different line weights in one element?
2 REPLIES 2
fredrik
578 Views, 2 Replies
Hi all.
I'm facing a problem where I need a cut element (a basic wall with several layers) to use different line weights for different parts of the element.
In this case, I need the concrete to stand out when looking at the finished drawing, and the rest should just be indicated with thin lines. I've tried looking into this here and elsewere but I can't find anything that helps me. Is there a way to control the line weights (shown in plan view) so that one element uses different line weights?
See attached image.
Thank you for taking the time to help me out!
All best
/Fredrik
2 REPLIES 2
awes
in reply to: fredrik
Shortcut VG, Override host layers (bottom right) >Edit and adjust line weight for structure. Nice feature.
fredrik
in reply to: awes
Wow, that was easy! 🙂
Thank you Awes!
All best
/Fredrik
