Install Revit from Building Design Suite premium and moreover Professional Robot Structural Analysis, in the analysis tab in Revit, I only see "Reinsforcement check code", does not seem "Link Robot Structural Analysis", as active?
Solved by hungn. Go to Solution.
You need to download and install
Structural Analysis and Code Checking Toolkit 2014
Hung Nguyen
Cansel
I am looking for the 2013 structural analysis addin for revit 2013, is a version avaialable??
No, Its not available now on the website
I CANT SEE THE ROBOT LINK IN THE AUTODESK REVIT 2018 VERSION UNDER THE ANALYZE TAB.
@hungn wrote:You need to download and install
Hung Nguyen
Cansel
Hung Nguyen
Cansel
did you install this add in:
https://apps.autodesk.com/RVT/en/Detail/Index?id=4901636995211349921&appLang=en&os=Win64
DarrenP
Need Urgent Help Please
I have Robot Structural Analysis 2014 and Revit 2017 installed on my PC but I cant find the link which will help me export and Import Structural Models between the to applications.
Even after installing the Tool Kid which contain the Link, no link was visible
Will I be able to import and export Structural Models between the two applications of two different versions 2014 and 2017 ?
Robot Structural Analysis link is finally appearing in the Revit Application installed on my PC and all is working properly
Thankx
