Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Problem with revit extensions (Beam to Column Connection)
4 REPLIES 4
csouch
1935 Views, 4 Replies
I have the same issue with steel connections and rafter framing. All latest extensions and updates installed.
Please advise
4 REPLIES 4
Artur.Kosakowski
in reply to: csouch
These are different Extensions and the solution I suggested is based on the screen capture attached to this post and this particular Extension.
My understanding is that you have already registered as support case for the rafter framing but what is the exact issue with the steel connections?
Artur Kosakowski
csouch
in reply to: Artur.Kosakowski
Please see photos on the errors on the steel connections. These have worked well for me on a previous model.
Artur.Kosakowski
in reply to: csouch
As you have created the support request for this issue I will communicate with you within this support case.
Artur Kosakowski
This REX supports only I type sections.
Artur Kosakowski
