Solved by jhudtwalcker. Go to Solution.
Hi Stephen
did you solve this problem? if not, here's the solution: you have to pres CRTL+ENTER, but not in the drawing area, but in the properties field... Hope it works
Use shift+Enter to do the line break.
Mostafa Elashmawy
Dang it !:
Revit 2018:
Name cannot contain any of the following characters:
or any of the non-printable characters.
CTRL+Enter for a force-break on multiline text.
Hello, do you know if this is still true?
When I try ctrl+enter or shift+enter I get an error saying:
"Name cannot contain any of the following characters:
or any of the non-printable characters."
I'm using Revit 2021.
