Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Diameter symbol
6 REPLIES 6
1207 Views, 6 Replies
Diameter symbol
Does anyone know how to get symbols, like diameter, to show up in text?
Jeremy
6 REPLIES 6
Use the Microsoft character map. Go to "Run" type charmap. Find the diameter symbol click the button "Select" then the button "Copy" then go back to your text in Revit and go to "Edit" and "Paste from Clipboard"...and there you go.
Now if we just had superscript 4, and decent centerline and plate symbols that are text instead of line symbols!
Alt + 0216 ?
wrote in message news:5526444@discussion.autodesk.com...
there you go.
Thanks, I really appreciate it. Are there other symbols available and if so
is there a list.
Thanks again,
Jeremy
"F. Gump" wrote in message
news:5526540@discussion.autodesk.com...
Alt + 0216 ?
there you go.
Yes, there is a list. Use character map as mentioned by previous poster.
the ALT code is noted in the bottom right corner, as you click on the
symbols.
"Jeremy" wrote in message
news:5527247@discussion.autodesk.com...
is there a list.
Thanks again,
Jeremy
Alt + 0216 ?
there you go.
or http://www.tedmontgomery.com/tutorial/ALTchrc.html
other options:
http://www.google.com/search?hl=en&q=alt+codes&btnG=Google+Search
note, the charachter you get with each alt code may differ depending on the
font.
is there a list.
Thanks again,
Jeremy
Alt + 0216 ?
there you go.
Thanks again. I'll try that.
news:5527477@discussion.autodesk.com...
symbols.
is there a list.
Thanks again,
Jeremy
Alt + 0216 ?
there you go.
