Yes, there is a list. Use character map as mentioned by previous poster.
the ALT code is noted in the bottom right corner, as you click on the
symbols.
"Jeremy" wrote in message
news:5527247@discussion.autodesk.com...
Thanks, I really appreciate it. Are there other symbols available and if so
is there a list.
Thanks again,
Jeremy
"F. Gump" wrote in message
news:5526540@discussion.autodesk.com...
Alt + 0216 ?
wrote in message news:5526444@discussion.autodesk.com...
Use the Microsoft character map. Go to "Run" type charmap. Find the
diameter symbol click the button "Select" then the button "Copy" then go
back to your text in Revit and go to "Edit" and "Paste from Clipboard"...and
there you go.
Now if we just had superscript 4, and decent centerline and plate symbols
that are text instead of line symbols!
