Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Problems in exporting Revit model to Autocad
4 REPLIES 4
milind_p
537 Views, 4 Replies
We are preparing MEP models in Revit, but are facing problem in exporting the views to Autocad. The fittings do not remain in place and get scattered in CAD file. Can this be avoided, and if the drawings can be published in CAD?
4 REPLIES 4
Jrobker
in reply to: milind_p
The interoperability between Revit and AutoCAD isn't perfect. You are going to get unexpected results.
If you export to Acad of course you can publish from there.
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
from setting under mechanical setting
make the inside and outside gap 0
stevenmathias1
I realize that this is an old post, but I'm still facing this issue using Revit MEP 2013. Has anyone found a solution to this problem?
gurselgunacar
i have the same problem. And couldnt find the solution
https://www.bilgitara.com
