Revit MEP
Message 1 of 4 (415 Views)
Accepted Solution
Formulas for Annotations
415 Views, 3 Replies
02-04-2013 09:00 AM
Is there a way to get a zero value to not show up when tagging a fixture without having three different family types within the annotation tag ?
Can a formula be written to exclude the zeros within a single label ?
*Expert Elite*
CADastrophe
Message 2 of 4 (378 Views)
Re: Formulas for Annotations
02-04-2013 09:34 AM in reply to: BrianAd
You cannot force your parameter to a null value (either manually or via formula) which would be the only way to get the Tag to ignore it. The only way to have a single Tag Type with all three of those parameters referenced as behave as you describe, is to ensure that the 0-value parameters do not exist with the Family. This means that you will need to have either multiple Tag Types, or multiple Family Files for the associated elements.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 4 (366 Views)
02-04-2013 11:01 AM in reply to: CADastrophe
Thanks for the reply.  I just stumbled onto something, when you create a new family from the Generic Model template and change the Family Category and Parameters to Plumbing Fixtures the WFU, CWFU, and HWFU values are blank (no value at all, just blank).
In my current family I can't delete the unwanted FU's, CW & HW, the delete option is "greyed" out.  I just changed the Category to Electrical Fixture and I was able to delete the CWFU & HWFU, I then changed it back to Plumbing Fixture and the zero values are gone, they are just blank and no longer show up as zero's for my tagging.
That just made my day.  I can now tag without the zero's showing up and I can schedule them without all the zero's showing up.
*Expert Elite*
CADastrophe
Message 4 of 4 (361 Views)
02-04-2013 11:10 AM in reply to: BrianAd
Nicely done! That's a good trick.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
