Revit MEP Forum
Default Libraries on revit 2014
1 REPLY 1
jgarciab
1148 Views, 1 Reply
Hello, so I'm new at revit and have the 2014 Student version y have been working with some architectural and MEP designs and Im having had the following problem: every time I try to connect pipe line to an equipment I get a message telling me that revit could not find a matching pipe segment and sends me to check my routing preferences when I do that it seems like I don't have the revit default libraries even when I try to select a pipe fitting revit tells me that I don't have any fittings family and sends me to a empty folder looking for them.
I have tried to make the windows repair function on the control panel and in tells me that revit has updated successfully but the problem doesn't fix.
Any ideas?
1 REPLY 1
lanl
in reply to: jgarciab
Hi jgarciab,
You have to make sure that the machine has a good network connection, and try to quit the anti-virus software and firewall temporarily.
Then follow the steps below to install the content libraries.
http://help.autodesk.com/cloudhelp/2014/ENU/Installation-Revit/files/GUID-851D6C9F-3E00-460D-B49E-34...
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Lei Lan
Rail Community
