hi
I have've drawn five Conduit And I'll schedule the following categories: Conduit Runs Four types of shows....
By chance, did you use the Change Types function? (only available when a Conduit Run is selected). If so, another user had discovered a strange behavior with this tool and we discovered a method of fixing it.
Link: issue with conduit runs and schedules
If that is not the cause of the problem, then make sure that the delinquent Conduit Run is of the "Conduit without Fittings" Type. Conduits that are "Conduits with Fittings" do not appear in Conduit Run Schedules.
Hi
I've tried
This way I did, but did not change .
Where is the problem.
Can you identify which Conduit Run is being excluded from the Schedule? If so, what is it's Type - "Conduits with Fittings" or "Conduits without Fittings"? Also, make sure that there aren't any Filters being applied to the Conduit Run Schedule.
