Revit Architecture
Valued Contributor
alex
Message 1 of 2 (75 Views)
custom materil problem
75 Views, 1 Replies
01-14-2013 06:32 AM
i wanted to make a 1/2" coated wire mesh material. in acad i renered a 1/2" section to file.
then in a paintshop i made a tansparent image and cutout png file.  both have the same dimensions and bit count.
in revit i made the material from image and it looks great but when i apply the cutout it does not line up with the same scale settings applies to both.  thanks, alex
Product Support
Message 2 of 2 (44 Views)
Re: custom materil problem
01-17-2013 04:34 PM in reply to: alex
When setting up the material image, and the cutout, make sure that the scale listed for both is the same. I found when I setup a new material, even though the size of the two images were the same, the defaults for scale were different.
Material ImageCutout
Lance Coffey
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
