Hi, I'm an engineering student and for my thesis I have to do a restoration project of a building. However, I have found some problems that I can not solve: first, I have to follow in a floor plan of the existing building from a raster image, and I can not make the walls created more transparent as to be able to know where to place windows and doors that you see in the plan but that the walls hide. Secondly I can not find a way to insert windows that are not the standard ones, but for example you can create indicating two points (maximum width). Thanks for your help and attention, Giovanna
Solved by constantin.stroescu. Go to Solution.
try these:
for 2. you can also use the method of inserting of a Curtain Wall into the Basic Wall and then apply Cut.....to make room for it...
In the following recording , you can see both metods....
https://chronicle.autodesk.com/main/details/8aefa7d1-f34c-4f66-b9e5-d67f70566d2b
