Revit Architecture
Active Contributor
Message 1 of 7 (567 Views)
Topo & Project base points
567 Views, 6 Replies
07-27-2011 01:27 PM
I started my project using 0'-0" for my first floor. Using level "shared elevation" to change 0'-0" to it's actual elevation of 1200.00' works for the building. However, when inputing the topo elevations the 1200 foot level does not correspond to the 1200 foot level when in shared level elevation. How do I adjust either base point so both read the same.
Employee
loboarch
Message 2 of 7 (556 Views)
Re: Topo & Project base points
07-28-2011 01:04 PM in reply to: steve
If you unclip (the paperclip icon) the survey point you can change its elevation to whatever your need is.  Then clip it back.  Now if you set your contour lables to used the shared coordinate they will read 1000+'
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Active Contributor
Message 3 of 7 (553 Views)
07-28-2011 01:16 PM in reply to: steve
I don't see a paperclip or a pin. where would this be?
Employee
loboarch
Message 4 of 7 (551 Views)
07-28-2011 01:20 PM in reply to: steve
When you select the survey point the paperclip is to the left side of the triangle point.
Jeff Hanson
Active Contributor
Message 5 of 7 (550 Views)
07-28-2011 01:23 PM in reply to: loboarch
Found it when I clicked on the project base point. Thanks, I'll give it a try and let you know how it turned out.
Steve Clark
Stephen Clark Architect
14900 Pierce Road
Saratoga, CA 95070
voice: (408) 867-09980
Active Contributor
Message 6 of 7 (546 Views)
07-28-2011 01:27 PM in reply to: loboarch
Thanks Jeff,
I must have spent 4-5 hours yesterday and today trying to figure out what to do. Tried to find what I was missing in "Mastering Autodesk Revit Architecture 2011, got frustrated and ordered 2012 version.
Thanks again. I'm back on schedule.
Steve
Distinguished Contributor
Message 7 of 7 (68 Views)
02-24-2014 02:17 PM in reply to: steve
I read this post a few days ago and thought every thing was okay once I input the items.
But now it seems like its all screwed up
I have imported a civil plan and made a topo for it in revit. so the topo mass came in at a much higher elevation.
so I went back to my paperclip to try and change some figures, but I get so confused by whats cliped and unclipped that some how. I get negative numbers and postived but none is actaully based on the corrected level. I am always getting numbers 100 or 200 off going in either directed
Is there a way to reset?
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
