Export an imported Image from Revit
2 REPLIES 2
1681 Views, 2 Replies
Hi there,
I'am having an Image in Revit but don't have the Image separately but I need it. How can I get that from Revit. I've tried Export-Image&Animation-Image but the view only get exported.
Thanks & Regards,
Marudhu Pandian.V
2 REPLIES 2
LisaDrago
As you go thorough he export what are you getting?
Are you getting the option to select what you want to export?
See image for reference.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
rosskirby
Just export that view to CAD.  When you do, in the same folder where the CAD file is exported, you'll see the image file as a .jpg as well.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
