Hi there,
Is it possible to change the Revision Number as starts from 0,1,2,....... in Revit Titleblock. If it is could you explain. See the snapshot I've attached.
Thanks in advance
Marudhu Pandian.V
I believe the best method would to set the first Sequence's 'Numbering' to "None" with the rest to "Numeric" and then manually place Text for the "0" within the Title Block Family on top of the Schedule, if you need to show that.
Nice idea ...but from my experience it is not gonna work.
For "cad" way of thinking and hiding stuff in your model, this method is just perfect!
What happens when I need to create a list of drawings that are issued in this rrevision?
...or cloud the stuff I have changed for this revision? Revit is not picking up the revision with no number/letter.
Is there a way to really make Revit count from ZERO?
If you go to View-sheet composition-revisions, on the bottom right it says numbering options and you can click on numeric and change the sequence starting number to "0". If anyone has this issue in the future.
