I am creating a beam system. I click the "beam system" button on the structure panel. However, it then goes into sketch mode without stopping to allow me to select "automatic beam system" and/or "Tag on Placement." Fortunately, I can see that "automatic beam system" is already selected in the split second that flashes before going to sketch mode. However, I do not have the opportunity to select the "Tag on Placement." I am really new to Revit and thus I am wondering if there is a different way to possibly turn on the tagging since the way I know is not an option. This may be very easy and I just am not experienced enough to know. Any help would be appreciated. Thanks!
Hi Mavarholak, You can find the detailed answer in the help."There must be a closed loop of supporting elements (walls or beams) already drawn, or the program will automatically redirect you to the Create Beam System Boundary tab. " So if there’s no closed loop, you will redirect to the Create Beam System Boundary tab. Hope this helps.
