Viewport / Crop Region/Annotation Crop
hliS658H
Message 1 of 9
hliS658H
I am very puzzled by this situation I ran into.
I had this crop region and annotation crop checked to be visible, I didn't see the elevation tag.
After I unchecked them,  the elevation tag showed up.
Then I noticed there is a thick rectangular frame there, it seems to be viewport. So I wonder if adjusting the viewport size can make the elevation tag invisible? How to adjust viewport size then?
I thought it might be the crop region shape, so I tried simple rectangle crop region, the elevation tag still showed up even though it was not within the crop region and not within the annotation crop.  Don't crop region and annotation crop alone control what are to be included in the view?
I might not have made my question clear,  let me give it another try. The problem is the crop region and annotation crop don't exclude unwanted objects when they are turn off to be invisible. It seems the visibility of the crop region has effect on the visibility of the view content, it shouldn't, right?
  • When I had the crop region and annotation crop turned on, everything was fine. When I single clicked the view NOT activated the view, I saw  a rectangle there which was very close to the crop region. I want to mention - this rectangle I am talking about is invisible until I single click the view,  I didn't activate the view.hliS658H_3-1659740047709.png
  • When I turned off the crop region and annotation crop - they were invisible but obviously they should still be working - however,  some elevation tags popped out.  When I single clicked the view NOT activated the view, I could see  a rectangle there and the unwanted elevation tags were within the rectangle. This rectangle is not visible if I didn't touch the view.
It looks like this rectangle controls the visibility of the elevation tags.
Replies (8)
Message 2 of 9
mhiserZFHXS
Activate the view port and drag the control for the left extent to wherever you want it.
Message 3 of 9
You could break the crop into two parts and then drag the two parts closer together.
https://blogs.rand.com/support/2020/05/revit-how-to-move-a-portion-of-a-split-cropped-region.html
Message 4 of 9
hliS658H
How to edit this viewport ? - it is not the crop region.
Message 5 of 9
Activate the view, make crop region visible (tick the box from properties), select it, and edit view crop.
Message 6 of 9
hliS658H
I finally figured it out.
I have to keep annotation crop checked (although the tags are out of annotation region);  this won't show annotation region dash line.
Once I checked annotation crop and keep crop region visible unchecked, those tags disappeared.
Message 7 of 9
Probably lack of oxygen is to blame.   Are you working at a very high elevation?  😉
Message 8 of 9
hliS658H
If you are talking about view range, this is the view range.  To be honest, I have never had this issue before, and I still don't quite understand why I have to keep the annotation crop checked, but it just works.
Message 9 of 9
fahylinda74RVL
Community Visitor
Community Visitor
thank you I had the same problem!!
