ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Export gridded PTX files?
5 REPLIES 5
cheliotes
898 Views, 5 Replies
It would be nice to be able to export gridded PTX files for use within programs which require them (i.e. Edgewise). Are there any plans to move in this direction?
5 REPLIES 5
have the same question 2016
Could you explain a bit more what you mean by "Gridded PTX files"
Standard ptx (ascii) each scan in separate ptx-file:
// I have added som comments after each line
12565 //lattitude grid cells, sphereic relation to the scanners position and rotation angel between cells
4700 //longitude grid cells
752.639056999993 625.250815000385 42.085689 // x,y,z of scanner position.
-0.157309 0.987549 0 //3X3 matrix
-0.987549 -0.157309 0 // -||-
0 0 1 // -||-
-0.157309 0.987549 0 0 // full 4X4 matrix
-0.987549 -0.157309 0 0 // -||-
0 0 1 0 // -||-
752.639056999993 625.250815000385 42.085689 1 // -||-
-1.300339 -1.056778 -1.678848 0.205203 116 129 101 // here starts messured coordinates
-1.302322 -1.058395 -1.679733 0.203494 129 143 108 // each line is a point. To get the world coordinate, multiply point with the 4X4 matrix.
-1.301895 -1.058060 -1.677505 0.215702 118 138 101 // each point is x, y, z, intensity, red, green, blue. The color is a int 0-255
... // here follows millions of lines exluded in this example
Here follows the same ptx header whitout comments:
12565
4700
0 0 1
0 0 1 0
Best Regards
/C
Hi, is this posible to get this export alternative?
Best regards,
C
Sounds like a good idea. Please submit your ideas or new feature requests on the Recap 360 idea page . Someone from the ReCap team will definetly consider it for review.
Ashwini
Rail Community
