Hi my friends, i've a problem with autocad 2014 and my pointing device.
My system is: Windows 8.1 Pro x64 , Radeon hd8890m 2GB , 16Gb ram , 256 ssd samsung 840evo , Logitech Performance MX (with own remote controller dedicated) , Logitech K800 Keyboard (with own remote controller dedicated) , 3dconnexion space navigator .
Sometimes, while using autocad, the scroll wheel mouse increase by itself the zoom.. have to change windows on my desktop (for example, open browser, or word..) and use the scroll over it.. then, back to autocad, zooming is ok..
I don't know why it happened. I've latest driver for any pointing device and others.
Thanks in advance.
Do you have the latest AutoCAD service packs installed?
Hi, thanks for the support! Yes, i've already installed SP1 on my autocad 2014.
Any other suggestion?
Thanks!!
Is it only happening in a specific drawing or all drawings? When you open the acad.dwt is it doing the same?
I know this is an old thread, but I have the same problem quite often.
I use the Logitech Performance MX mouse as well. That must be the source of the problem. I have a second mouse plugged into the computer (shows you how often it happens) to use whenever this happens, and it immediately fixes the problem. I also noticed if you save the file it seems to fix the problem most of the time, at least for a while.
I have dealt with it on different computers in many different files with the same mouse in ACAD 2013, 2014 and 2015. They were always the most current versions.
Anyone have any ideas why this specific mouse is doing this?
I disabled smooth scroll on my Logitech mouse and that permanently solved the problem. Hope that helps!
