I seem to be having some problems when trying to run an action script on a workflow transition. The script works fine if I use it in the 'edit' behaviour instead.
Is there some system issue stopping workflow transition scripts from running?
David.
Solved by dkeeley. Go to Solution.
Havent seen an issue with action scripts in the workflow. What is the error message that is generated and what does the script do?
Hi Joe,
I have been getting some support from Andrew Shaw at Autodesk support on this. It's being caused by a bug. The PLM 360 development team are investigating.
David.
