Is it possible to define a parallel workflow route. Our New Product form collects sign offs that do not need to be in a serial route, and would be much more efficient if the tasks (or transitions) were issued at the same time. We need to have separate tasks so that we can record who signed each task off (otherwise we could just run multiple approves on a stage)
Solved by JohnCHill. Go to Solution.
Think I may have found my own answer. Have multiple looped transitions to the same stage with different approvers for each. Then an exit transition that works out whats left to do. Seems to work at the moment
Hi Greg,
Yes you can create parallel states and transitions in your workflow.
Great work being able to track down a solution to your issue.
John
