PLM 360 General
Message 1 of 16 (275 Views)
Accepted Solution
Change Milestone State using scripting
275 Views, 15 Replies
01-05-2013 05:29 AM
I want to be able to change the workflow state referenced by a milestone via scripting. The WikiHelp seems to suggest this is possible but I have not been able to get it to work. My script is as follows;
item.milestones[0].setWorkflowState('[99] Cancelled');
The Wikihelp states the following;
Methods on the Milestones Array
milestones.setWorkflowState("SHORT_NAME")
Method to set the workflow state associated with the milestone (milestones.workflowState). The "SHORT_NAME" parameter takes the value for the milestones.workflowState.shortName property.
Can you please let me know what I'm doing wrong?
David.
Message 2 of 16 (262 Views)
Re: Change Milestone State using scripting
01-05-2013 02:07 PM in reply to: dkeeley
Also,
is it possible to change a milstone date after it has been created using scripting?
David.
Product Support
Message 3 of 16 (250 Views)
01-07-2013 07:07 AM in reply to: dkeeley
David,
Workflow states dictate milestones, not the other way around. You can have a workflow state create or adjust a milestone, or look at a milestone for a condition of validation, but you cannot have a milestone adjust a workflow state.
Also yes you can adjust a milestone date via scripting after the milestone is created, if you know the name of the milestone your trying to affect.
Joe Piggee
Support Specialist
Product Support
Autodesk, Inc.
Message 4 of 16 (248 Views)
01-07-2013 07:29 AM in reply to: piggeej
Hi Joe,
Thanks for the reply. So if I understand you correctly it is not possible to change the workflow state asscoiated to an existing milestone via scripting?
David.
Product Support
Message 5 of 16 (246 Views)
01-07-2013 07:38 AM in reply to: dkeeley
David,
There isn’t a way for a script to start based on when a milestone changes. Scripts only work on workflow changes or item creation / change.
Joe Piggee
Support Specialist
Product Support
Autodesk, Inc.
Message 6 of 16 (244 Views)
01-07-2013 07:41 AM in reply to: piggeej
Joe,
I think we have our wires crossed. The script is executed by a workspace behaviour (edit). All I want to do is change the workflow state referenced by the milestone at that point.
Does that clear things up?
David.
Product Support
Message 7 of 16 (240 Views)
01-07-2013 08:06 AM in reply to: dkeeley
David,
If you are trying to change the workflow step based on a milestone. Then you are looking at an ‘if’ or 'case' statement and using:
                item.performWorkflowTransition(transID, 'comments')
Joe Piggee
Support Specialist
Product Support
Autodesk, Inc.
Message 8 of 16 (238 Views)
01-07-2013 08:32 AM in reply to: dkeeley
Hi Joe,
I think we still have our wires crossed ;-)
I'll PM you to discuss further.
David.
Message 9 of 16 (231 Views)
01-07-2013 12:49 PM in reply to: dkeeley
Hi Joe,
I have tried to illustrate what I am trying to do on the attached document. Please let me know if this sheds any light.
David.
Product Support
Message 10 of 16 (222 Views)
01-08-2013 06:28 AM in reply to: dkeeley
David,
Based on what your showing all you can do at that point is set the “Closed” milestone to completed at 100% and create a new milestone for “Cancel”.
You cannot change one milestone for another or delete and replace the milestone by scripting.
Joe Piggee
Support Specialist
Product Support
Autodesk, Inc.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
