Is it possible to add a new row to a matrix at runtime (during for creation/edit)
Solved by JohnCHill. Go to Solution.
Hi Greg,
The ability to add rows to a matrix when you are creating a record is not available at this time. If you find you need more rows in a matrix you will need to go into the Item Details tab, Workspace settings in the Administration menu and add additional rows, fields from there.
John
