Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Image Drape - Not working right
4 REPLIES 4
1281 Views, 4 Replies
I tried to follow the directions I found in the below blog.
http://fromthegroundup.typepad.com/f...avisworks.html
The problem I have is that I can get the image to show up but it loses it's color and is also rotated differently then I had it my Civil3d drawing. As of right now I just have the image loaded into my Civil3d drawing do I need to somehow attach to the surface?
Tags (3)
4 REPLIES 4
lee.mullin
What type of image file is this? If you go into a photo editing application and save it as a JPG or BMP do you have the same issues?
Can you try creating a new material using that image inside the Navisworks Presenter window?
Do you have any screenshots of the current settings and result?
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
in reply to: lee.mullin
The aerial image is in jpg format. I've attached a couple of screen shots of what the image looks like in my source drawing and how it looks when it shows up into Navisworks. I havn't tried creating a new material I'll give that a shot.
lee.mullin
How did you get on with creating a new material or saving the JPG as a BMP? I think this may be an issue with the settings in the JPG and Navisworks displaying it incorrectly, if you can upload the JPG I can look at this too.
Lee Mullin
Autodesk Ltd.
I had a similar issue as well, but then I took a look at my surface and the aerial overlay that I was using and there was some gaps at the edges. I moved my edge points so that the boundary of the surface matched the extents of the aerial photo and it came in okay.
The problem I was having in Navisworks was that once I rendered the aerial overlay on my surface, it would disappear as soon as I clicked on anything. I am not sure how to get the aerial overlay to "stick" to the surface...
Tags (1)
Rail Community
