Watch Save\SaveAs Event?
Message 1 of 8
I am fairly new to vb.net programming so sorry if this is an elementary question. I checked some post but didn't see what I was looking for.
I want to know how to watch for a save or saveas event. Basically I want to start a command after a save or saveas commands are finished. BTW, I'm coding this in vb.net.
Dan
Replies (7)
Message 2 of 8
Hi.
I will give you a code sample in C#.
You have to handle the DocumentLockModeChanged event like this:
Application.DocumentManager.DocumentLockModeChanged += new DocumentLockModeChangedEventHandler(callback_DocumentManager_DocumentLockModeChanged);
and then check if the command is SAVE or SAVEAS:
private static void callback_DocumentManager_DocumentLockModeChanged(object sender, DocumentLockModeChangedEventArgs e)
if (e.GlobalCommandName == "QSAVE" || e.GlobalCommandName == "SAVE"
|| e.GlobalCommandName == "SAVEAS")
// do you code
the end of the command will be like #SAVE #SAVEAS.
Edited by: maxim_voloshin on Jun 24, 2009 6:59 PM Edited by: maxim_voloshin on Jun 24, 2009 7:00 PM
Message 3 of 8
Thanks for the code. I was able to write this in vb.net but it doesn't seem to watch the Save\SaveAs\QSave event. During the debug it doesn't even get into the code.
here's what i have so far. I'm a noobie so bare with me. Thanks!
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Public Class Class1
Private Sub Sub_Handler()
Try
AddHandler Application.DocumentManager.DocumentLockModeChanged, New DocumentLockModeChangedEventHandler(AddressOf docChange)
Catch ex As Exception
End Try
End Sub
Public Sub docChange(ByVal sender As Object, ByVal e As DocumentLockModeChangedEventArgs)
If e.GlobalCommandName = "_QSAVE" Or e.GlobalCommandName = "_SAVE" Or e.GlobalCommandName = "_SAVEAS" Then
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
ed.WriteMessage("Save has occured")
End Sub
Message 4 of 8
Well after playing around here's what I got. It will watch the save events. I placed a message box to show me if the watch worked but it seems to be displaying twice. Maybe at the beginning of the command and at the end. I want just the end so that my next task will run after the save is completed. Any feedback will be greatly appreciated. TIA.
Imports System.Windows
Public Class Class1
Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
Dim subHandler As [Delegate]
If e.GlobalCommandName = "QSAVE" Or e.GlobalCommandName = "SAVE" Or e.GlobalCommandName = "SAVEAS" Then
Application.ShowAlertDialog("Save has occurred")
End Sub
Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
Try
subHandler = New DocumentLockModeChangedEventHandler(AddressOf docChange)
AddHandler Application.DocumentManager.DocumentLockModeChanged, subHandler
End Try
End Sub
Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
RemoveHandler Application.DocumentManager.DocumentLockModeChanged, subHandler
End Sub
End Class
Message 5 of 8
Try
If e.GlobalCommandName = "#QSAVE" Or e.GlobalCommandName = "#SAVE" Or e.GlobalCommandName = "#SAVEAS" Then
Message 6 of 8
Sorry that didn't work. I still get two dialog boxes. Any other suggestions.
Thanks for the reply!
Message 7 of 8
cadMeUp
Check out the attached file for monitoring Database 'save' events. Just displays an alert dialog when Database.BeginSave & Database.SaveComplete are called. The sample code file is for AutoCAD 2009 VB.
Message 8 of 8
Thanks! I will give that a try.
