Hey there,
I want to know how I can get exact distances on my UV maps.
I unwrapped my 3D DSLR camera model and I want to manage that the texts and signs on the texture have exactly the same distance like in reality. So how can I get those exact distances?
Cheers
@Anonymous wrote:
Hey there,
Cheers
Hi.
UV coordinates use different units of measurement from 3D models, so it is not possible to get a corresponding distances of UV coordinates. Instead, you have a finite UV Map space with minimum value being U:0, V:0, and maximum value being U:1, V:1, no matter what your texture size is. If your 3D model has corresponding vertices that you can use as distance markers and the corresponding UVs are free of distortions, then Render your UVW template via Unwrap Modifier's UV Editor -> Tools -> Render UVW Template. You can then place your "signs" and "texts" accordingly in Photoshop.
Having posted my previous reply, one crude way to force your UVs to read out measurements that mimc real-world units is by copying the map channel info via Channel Info utility and paste it to Mesh data channel. This works with Editable Mesh.
Do not do this on your original:
1. Duplicate your model and convert to Editable Mesh.
2. Go to Utilities panel and go to More -> Channel Info.
3. Copy the object's "map" channel and paste it into the "mesh" channel. Your model will now look like your UV layout in a much smaller scale. The scale of your new mesh will correspond proportionately to your scene unit. For example: If your UV cluster takes up exactly 25% of your UV Tile and your scene unit is 1 inch, then your mesh will 0.5 inch. This new mesh has nothing to do with your actual UVs. It's just a 3D representation of your UV layout.
Hope this makes sense.
