Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Inventor Publisher 2013 Insert Dialog problem
5 REPLIES 5
alvarovq
1111 Views, 5 Replies
I'm an student trying the student version of Inventor Publisher 2013 for students (spanish language).
I found that when the program displays the insert model dialog box I see the preview box over the top left of the windows over other elements of this window, so it's quite anoying because it hides some object behind it.
I've attached an illustrative image.
Is there any way to disable the preview box or to resize it?
Thanks in advance,
Álvaro.
5 REPLIES 5
irene.chen
in reply to: alvarovq
Hi Álvaro,
Thanks for your feedback, I can't reproduce the issue you mentioned. could you please provide me more detail information?
  1. Which OS are you using? XP, Win7?
  2. Is it a 32bit OS or 64bit OS?
  3. So you’re using Publisher2013 right? And do you have a SP? If so SP1 or SP2?
  4. Some of your hardware information would also be helpful, so we can mimic your environment
Irene Chen (irene.chen@autodesk.com
Inventor Publisher QA
alvarovq
in reply to: irene.chen
Hi Irene,
Thanks you for your quick response.
I'm using Windows 7 64 bit (Spanish).
I'm trying the Publisher 2013,spanish as well, and with the SP2 installed (first solution I tried).
As a hardware I use a Dell Precision T7500 (Intel Xeon E5507, 12 Gb RAM, Video Card Quadro FX 580), with 2 Monitors. Just formated and reinstalled (windows updated to SP1 and with all the updates installed).
Best regards,
Álvaro.
alvarovq
Hi again,
Adding more information: I read about the SP3 and installed it yesterday, I sill have the same problem.
Best regards, Álvaro.
irene.chen
Hi Álvaro,
Thanks for your feedback, I've added this issue with all information to your internal issue tracking system.
Irene Chen
a_angel
I just installed SP3 and have the exact same problem, and it looks exactly the same as the original picture from Alvaro.
The one workaround is to use large icons so at least the names are visible but please fix this annoyance.
Autodesk Publisher 2013 SP3
Build 5.3.0.31 64bit
Intel Xeon 2.4 GHz
Nvidia Qudro 4000
Ram 12.0 GB
Cheers
