Notch Feature Option for laser cutting
I like to see a notch solution for this types of issues:
Solution maybe something like a checkbox within The Notch feature.
(Checkbox) Cut perpendicular to smallest intersection
19 Comments
Delmeco
Problem:
Angle of a pipe end can be to sharp for a (pipe)lasercutting machine. The machine will be out of range by angle and/or material thickness.
It would be nice if framegenerator will be expand with a tool it makes it possible to simply calculate the shorten/lengthen dimensions by given an minimum and/or maximum angle "straight" to pipe wall so the pipe can be cut by a lasercut machine and will fit.
Also a possibility to give up welding preparations would be great.
Marco.Takx
(See screenshots 1, 2, & 3)
kevinb
It would also be nice if we had a "round to nearest X" so that we don't get silly things like a 25'-0 1/32" long beam that's just going to be welded into place but that smidgen of corner left over adds just enough.
ms
I agree
marcelbeerta
Observer
this would be great
ms
whiskeymike
I would like to see this as well as a real focus of new features and capabilities around building with tube.   Much like the sheet metal module.
CAD.4.CAM
I wish this for years!!
andreas.ajax
If you like this post you might wanna check out my post 🙂
http://forums.autodesk.com/t5/inventor-ideas/frame-generator-notch/idi-p/5436997
dan_szymanski
Status changed to: Accepted
Accepted idea [12010]. Thanks!
dan_szymanski
Hello @Marco.Takx@Delmeco@Kevinb@marcelbeerta@whiskeymike@CAD.4.CAM@andreas.ajax@ms
Within the sample images provided within this idea, the solutions for the perpendicular cuts are relatively self explanatory.  I have a question that I would like to pose to everyone here.  Please take a look at the images below.  If we use a pipes inner diameter edge to make a perpendicular cut (on both sides), we will create an interference with the OD on the inner (45 degree) edge (See IMAGE 1).  How do you guys solve this problem in the real world with your cuts?  Do you leverage a combination of referencing the inner diameter on the outside (130 degree) edge and the outer diameter on the inside (45 degree) edge (IMAGE 2)?  Or do you solve it using some other mechanism?  Please share any comments or feedback here.  Thanks!  Dan
IMAGE 1
IMAGE 2
Marco.Takx
Hi @dan_szymanski,
I like to see this automatically.
Now I have to create this manually and takes a lot of time.
Marco.Takx
 Hi @dan_szymanski,
I like to see this Automatically.
Now I have to create this every time manually and takes a lot of time.
martin.pelak
dan_szymanski
Some possible solutions for this idea are currently under discussion on the NDA based Inventor Feedback/Beta forums. If you would like to contribute/validate then please apply for access using this link:
https://bit.ly/InventorBeta
Then select the link Martin provided above.  Smiley LOL
dan_szymanski
This idea has been implemented within Autodesk Inventor 2020. Special thanks to everyone who cast a vote for it.
Marco.Takx
A lot of votes for the development team.
Good job guys!!! 💪
kencameron6NPYE
Community Visitor
@dan_szymanski
Is there any updated info on how this has been implemented?
dan_szymanski
Hello @kencameron6NPYE ,
There is some documentation within the What's New content here.
We have delivered a number of other enhancements to Frame Generator in Autodesk Inventor 2021 as well. They can be viewed within the What's New content here.
