ISO break view
ISO break view
In the ISO view below, shouldn't the break line show as broken or jagged like a cut-out; so as not to be mistaken for an actual beak in the part.
9 Comments
timdown73
Break not "beak" sorry.
Paul-Mason
Correct representation of a cup & scoket in a shortened veiw prospetive and isometriv view instead of a stright line, as is current
DRoam
Can you post a screenshot of two of what you're describing?
Paul-Mason
Here's the screen shots. The first is what inventor produces in and IDW when creating a shortened view, the second is by creating and editing an ipt in a foreshortened way to produce a representation of what I'm suggesting a shortened view should look like in an an IDW, as can be seen in the first screen shot it looks like two separate parts, where the break is should be either cup and socket or zigzagged as in the second screen shot
DRoam
Ahh, I see what you're saying. If I make a Break in an orthographic view, and then make an isometric Projected view from that view, the break displays as a plain gap between "pieces" in the Projected view, when it should display a jagged or S-shape break between both "pieces". I agree, this should be fixed.
FYI, there is a similar idea here which you might want to vote for: ISO break view
Paul-Mason
As you say in an ISO view this failure to show a cut/discontinued view can cause problems. I've also posed a similar suggestion to yours here http://forums.autodesk.com/t5/inventor-ideas/representation-of-a-cup-and-scoket-in-a-shortened-veiw/... Good to see I'm not alone in this chain of thought
Paul-Mason
@DRoam thanks for sharing the link been there and expressed my support
Nate1985
Hi
Has this ever been fixed in any newer versions?
Kind regards
Yijiang.Cai
Thank you posting this idea to us, and tracked as [INVGEN-68184]
