Show only
Search instead for
I'd love to make the team a "hole" allowed to build the holes on curved surfaces too, and not only on the edges. let it be a separate team. Create such openings making additional constructions and use the command "rotate" or "squeezing" is not good.
my wish is an modification off the hole function. It`s always annoying create an hole on round/courved surfaces. Everytime using Plane, Axis and Points to define the hole location.
Several years ago, I had to work with ProE Wildfire 3 and there it was so easy to do this.
You just have to pick one round/ courved surface and two measures, like in the picture, and it was done.
This is another case that is often in modeling parts. Now is very boring the sequence to do this: put a tangent plane, put a 2d sketch, draw a point, put the hole....
