D = d (Dimensions)
D = d (Dimensions)
Most of the time when I'm drawing, my cap lock are on.  If you type an uppercase D for a dimension value, Inventor doesn't recognize it as a variable.  I want Inventor to treat uppercase and lowercase D's the same in dimension dialog boxes.
6 Comments
timdown73
crmayo
Hi Tim, it is similar but the other idea involved units and only specifies MM and IN characters.  The idea was accepted and didn't mention any across the board change of replacing all uppercase text with lowercase.  I would like to keep it simple, only change on a case by case basis.  Perhaps someone from Autodesk can give us some insight on what they plan on implementing.
timdown73
Agreed.  It's also similar to the Content center part information all in lowercase.  Here our BOM needs to be all uppercase.  Frustrating, but I don't want to confuse your post any further.  I hope they listen.
kevinb
I think this is because of the fact that the dimension number is a parameter, which are case sensitive.  The "d#" parameters are auto generated as you create unnamed dimensions, as a result it would have to be all or none capitalized, or case sensitivity would have to be removed.  Considering that you can't have spaces either, I suspect coding wizardry is to blame.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
