Inventor Forum
thus and reverse assemblies in Inventor 2012
3 REPLIES 3
308 Views, 3 Replies
I am creatng columns and beams for a power plant and a few of my assemblies that I have drawn in thus have a reverse - is there an easy way to reverse the assembly?
Thank you for your help 🙂
Angela
3 REPLIES 3
blair
1.) Either use the "Back" for your base view rather than the "Front".
2.) You could unground the base component in the IAM and change the orientation which will flip the model.
3.) In the IAM, view the view cube and RMB on the View cube and set your Front there with the "Set Current View>Front.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
You may be able to just use mirror.
T.S.
I used mirror and adjusted a bit some of the features that did not mirror exactly....
