Inventor General
Member
Message 1 of 2 (167 Views)
iPart Appearance issue
167 Views, 1 Replies
01-13-2013 07:14 AM
Hi! This is my first post in this community and I'm not a good English writer, thus sorry for the poor grammar.
Well, I created an iPart (the base feature is an Extrude) and I defined the Appearance Column in the iPart Author, that's OK. But, when the base feature is Revolve, the solid of the part isn't generated inside the Member files. It sounds some bug. Have somebody tried the same problem?
Thanks to everyone.
Member
Message 2 of 2 (128 Views)
Re: iPart Appearance issue
01-16-2013 03:39 AM in reply to: darlanbecker
I found the problem. The Sketch needs to have one dimension at least.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
