Inventor General
Distinguished Contributor
Message 1 of 4 (646 Views)
adding to ordinate dimensions
646 Views, 3 Replies
03-20-2013 09:07 AM
I have had to revise a part that someone else created at some earlier date.
They used the ordinate dimensions, which works perfectly and looks good.
I have had to add some holes to this part, but can not figure out how to add more dimensions
to the existing ones, outside of deleting the dimensions and dimensioning them all over again.
How do I add more ordinate dimensions to the existing?
As always, thank you so much for educating me.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2013
ACAD Mechanical 2013
Cadmanto
Message 2 of 4 (644 Views)
Re: adding to ordinate dimensions
03-20-2013 09:12 AM in reply to: sps_cad_guy
As long as you have the target starting point you should be able to just select the view and the destination point and it should reference back to the already existing target point.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Message 3 of 4 (639 Views)
03-20-2013 09:22 AM in reply to: Cadmanto
Thank you. I didn't realize that for the first new hole, I had to select the center rather than an edge like with the remaining holes.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2013
*Pro
sbixler
Message 4 of 4 (620 Views)
03-20-2013 10:26 AM in reply to: sps_cad_guy
It depends on whether they were placed as an Ordinate Dimension Set or as independent Ordinate Dimensions.  If it's a set (when you click on one it selects all of them), then right click on any one of them and choose Add Member.  If they are independent, use Scott's method.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
