Inventor Forum
Wood Carving
4 REPLIES 4
2418 Views, 4 Replies
Wood Carving
Hi I am a highschool student and last year I started a Gothic style throne chair in a woodworking class. I first drew it up in Autodesk Inventor and then created job plan sheets for each individual part. This semester I plan to finish the throne. I want to incorporate gothic themed carvings (designed by me) into the throne. Our school owns a 3D Router so my plan was to create the 3D carvings and have the router cut them into parts of my throne. My question is what software I should use to create the carvings. Should I use Inventor?
-Roy
4 REPLIES 4
blair
in reply to: 13088
If you have already modeled everthing in Inventor, all the pieces for the assembly, the next logical step would be to use the IPT's and import them into the CAM software for the NC 3D router.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
PaulMunford
in reply to: blair
You will want solid geometry for your CAM programming. This can be done in Inventor - see this film:
http://youtu.be/awXh8Svs9nE
You could use Fusion, 123D or AutoCAD - but you wouldn't maintain the parametric relationship with your inventor IPTs.
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Curtis_Waguespack
in reply to: 13088
Hi 13088,
As a student I think you will learn a great deal in terms of technique by modeling some of the carvings in Inventor. But if you were to pursue this professionally or even as a serious hobby, you would want to be aware of other software that is dedicated to the CNC woodcarving industry, such as these examples:
http://www.vectric.com/WebSite/Vectric/vcp/vcp_index.htm
http://www.carve3d.com/index.asp?pageID=6
http://www.vectorart3d.com/
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Thanks a lot for all of your replys. The software the router uses is Cut3D which I believe is a product from Vectric. I will look more into this.
