Inventor Forum
VBA: Distinguish hole features from other circles in drawing, add centermarks
2 REPLIES 2
CragMonkey
1379 Views, 2 Replies
I'm attempting to use VBA to put center marks on each hole in my drawing.
So far I have the following code:
    Dim oIntent As GeometryIntent
    Dim oCenterOfPart As Centermark
    'Add center marks to base view
    For Each oCurve In oBaseView.DrawingCurves ' <- need to identify Hole Features
        If Not oCurve.CenterPoint Is Nothing Then
            If oCurve.CurveType = kCircleCurve Then 'CurveTypeEnum
                Set oIntent = oSheet.CreateGeometryIntent(oCurve)
                Set oCenterOfPart = oSheet.Centermarks.Add(oIntent, True, True)
            End If
        End If
    Next oCurve
    'Add center marks to top view
    For Each oCurve In oTopView.DrawingCurves ' <- need to identify Hole Features
            End If
        End If
    Next oCurve
    'Add center marks to right view
    For Each oCurve In oRightView.DrawingCurves ' <- need to identify Hole Features
            End If
        End If
    Next oCurve
oBaseView is the DrawingView object representing the base view the code just placed. I also used VBA to place the projected views oTopView and oRightView. I want to add center marks to each hole when viewed from the end (as circles) and add centerlines when viewed from the top or side (as hidden lines).
I will be iterating through several models representing various handhold styles. The feet can be in many orientations, 99% of them are paralel to one of the origin planes (XY,YZ, or XZ).
This is what my code generates:
 (The centermarks that are selected are the ones I don't want the code to generate)
 This is what I WANT the code to generate:
 1) How do I distinguish whether a circle curve originated because of a hole or because of another cilindrical feature?
2) How to I identify the correspoding hidden lines in the other views so I can add a center line?
2 REPLIES 2
mrattray
in reply to: CragMonkey
I don't know that answer to your question, however these sort of questions usually get better answers in the customization forum.
Mike (not Matt) Rattray
CragMonkey
in reply to: mrattray
