Inventor General
Active Contributor
Message 1 of 2 (97 Views)
TEXTURE VISIBILITY
97 Views, 1 Replies
01-07-2013 08:26 AM
I posted a while back about an issue I had with a custom texture not showing up on my parts while they were showing up on a coworkers computer fine.  I received no good help on that post so I just ignored my issue.  I recently cured my own issue (I just needed to click Textures On in the View toolbar under Appearances).  I feel dumb even asking for help on that now, but I another issue arose.  I am thinking it is going to be a simple fix as well but I have not been able to find it.
Everytime I close out of a part or assembly it automatically turns the textures back off so I have to turn them on everytime.  I looked through the Application Options and Document settings to keep textures turned on but could not find anything.  Can anyone help me turn the textures on and leave them on?
CWW
*Pro
sbixler
Message 2 of 2 (86 Views)
Re: TEXTURE VISIBILITY
01-07-2013 11:50 AM in reply to: avaya2012
This option is stored in the Current_User section of the registry, and if I recall correctly, these settings are written (saved) when Inventor exits normally.  Sounds as if the registry is not getting the message, or you don't have sufficient access priviliges to that section of the registry.
For what it's worth, I have been having similar issues for the past three versions-- some of my application options, seemingly at random, are reverted to default.  I haven't found or heard of any solution for this, so I keep my exported settings handy for quick import.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
