Inventor General
Message 1 of 13 (497 Views)
Slicing a Sphere
497 Views, 12 Replies
04-16-2013 08:55 PM
I am trying to create a part that has a spherical feature. The spherical feature is "sliced" on the front and back to create a flat surface (see Compound Rest Handle Isometric image). Should I use workplanes to slice the sphere? What is an efficient process the slice the sphere. See Compound Rest Handle Front and Compound Rest Handle Back images and compare to the final result in the Compound Rest Handle Isometric image), Thanks.
*Expert Elite*
Message 2 of 13 (469 Views)
Re: Slicing a Sphere
04-16-2013 09:55 PM in reply to: rcobbjr
The easiest way would have been to Revolve the profile as the very first feature before adding the handles.
You could slice that one side but another way would be to start a sketch on each plane and select Project Cut Edges (from pull-down) and then Extrude - Cut the resulting circles pointing away from the center.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Valued Mentor
BLHDrafting
Message 3 of 13 (453 Views)
04-16-2013 10:36 PM in reply to: rcobbjr
Maybe revolve like this.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
*Expert Elite*
Message 4 of 13 (449 Views)
04-16-2013 10:44 PM in reply to: rcobbjr
Handle Sketch (assuming making as one part rather than multi-body solid).
*Expert Elite*
Message 5 of 13 (448 Views)
04-16-2013 10:45 PM in reply to: JDMather
*Expert Elite*
Message 6 of 13 (447 Views)
Second Revolve.
*Expert Elite*
Message 7 of 13 (446 Views)
04-16-2013 10:47 PM in reply to: JDMather
Third Revolve (add rectangle to sketch and do this as two revolves - New Solid if needing multi-body for handle).
*Expert Elite*
Message 8 of 13 (440 Views)
04-16-2013 10:48 PM in reply to: JDMather
Mirror and add Hole through center.
*Expert Elite*
Message 9 of 13 (436 Views)
04-16-2013 10:53 PM in reply to: JDMather
Not tangent.PNGYour attempt does not appear to be tangent.
Distinguished Mentor
Message 10 of 13 (394 Views)
04-17-2013 06:47 AM in reply to: rcobbjr
Unless you modeled it as a multibody part you may find spliting the front gives you results you do not like at all, as the handles will split too. You may in that case have to use an extrude to cut the sphere flat where you need it.
JD's method would work well, but revolve the handle as a seperate body as you will have to add the pin and pin hole to the sketch, which also means the spheres that hold the handles on will also have a flat spot on them for contact surfaces.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
