I just installed inventor on a new computer and all the assemblies I open that had content center fasteners are now missing links. How can I fix this?
Did you point the new install to the correct Content Center location? Is the Content Center Add In loaded? What version of Inventor? Desktop CC content or Vault?
hmmm,... did I miss anything?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
2012 product design suite, content center add-in is loaded, Using desktop CC content, no vault. Where should I direct the CC location to then?
Don't understand what the back up is and saved directory. Please clarify. Thnaks
I'm on my phone because I am travelling right now so I can't post any screenshots and I am going from memory here. Others might be able to help out better but here's the explanation:
The files that are created when you place a component from content center are saved to a specific location on your hard drive. This location is specified by default in your application options so look there to see where they are stored. You have the power to alter this and you may have done so I don't know. What I am trying to say is that the files you are looking for are only going to exist on your new computer if you copy them back over from somewhere else (e.g. the old computer, a back up store somewhere, etc.) the files themselves do not exist on the installation media. CC doesn't have any files in it, it is only a database, the files are created when you place a component. If you haven't backed up the files from your CC location (again, specified in the application options) you are probably screwed, but I would do a search on this forum because this has been discussed about 100 times in the past and there are smarter people than me on this forum.
Going forward, if you have lost all you CC files, I would suggest you alter the default location of any newly created CC files either by changing the default location in your application options or by setting it on a project basis using the project file. For example, our project files specificy a location within the workspace where all of our CC files are stored for that project. That way when the project file is backed up, moved, whatever, the CC files go with it.
Good Luck!
Good explanation. I think I might be screwed. All the parts I installed from content center were on my local c drive. Now I have a new computer and all assemblies are missing the hardware. I did save everything I had on my old "C" drive and made a search path in my project on the new computer and some, but not al lhardware i had were found. Making some progress. Thanks
