Inventor General
trumpy81
Message 11 of 15 (233 Views)
Re: Opening Files, Explorer vs. Thru the program
10-09-2012 09:03 AM in reply to: sbixler
Sam, if you open a file in WE and then save it the time stamp is changed. If you open the file using Inventor the time stamp is also changed, BUT Inventor will also update file paths etc... where ever it needs to, like Vault for example. It's true that the only change for the file will be the timestamp but that is often enough to signal vault that the file has changed. The files CRC value will be different also.
It's been a while since I actually played with Vault, at least as far back as 2010, it may have been earlier, but if memory serves, it was possible to locate the Vault files in WE. Don't ask me what address they were in though. This would have been when Vault used IIS (another disaster ... :smileyvery-happy: ).
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
Member
Message 12 of 15 (215 Views)
10-09-2012 11:47 AM in reply to: Dunehunter
I figured it out. I started a discussion with my block of cubicals and here is what we came up with.
Shortcut directories.
When you open files thru the folders provided on the left side of the "Open" dialog window you are only given the options of direct network paths. If you use the drop down or windows explorer you could end up using shortcut paths. If you use a shortcut path to open a part or assembly you could accidentally remap it to be located in that shortcut directory in whatever file uses it. Now if another user goes to open the file that uses it they will have missing links (as they do not have the same shortcut directories on their computers) that they will need to manually remap.
So opening files in explorer vs. in the program doesn't actually make a difference, it's that by not using the the folders provided by the ipj in the open dialog box you risk opening the file thru a path that has a shortcut in it.
~Jon
*Expert Elite*
dgorsman
Message 13 of 15 (211 Views)
10-09-2012 11:50 AM in reply to: Dunehunter
I only tinker a bit in Inventor, since some of our vendor skid packages are built that way, so take this with a VERY large salt crystal :smileyhappy:
Lets say you have multiple versions of Inventor to support different legacy projects - 2010, 2012, and 2013.  You double click a file to open it.  Are you certain that the file will open in the correct version?
More generally with AutoDesk products, many can not only open a variety of files but also support a number of different profiles for different plug-ins and configurations.  It could be a Bad Thing if somebody double-clicked a mechanical model and it opened in, say, a structrual design program.  The user closes the file and not thinking clicks OK when asked "Do you want to save?" (I see users doing this *all* the time).  Now you have a very irate designer who has a file which is more or less buggered; possibly still working but has content automatically added and/or modified by that other program and/or profile.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
trumpy81
Message 14 of 15 (184 Views)
10-09-2012 11:57 PM in reply to: dgorsman
Jon, you seem to be getting a handle on the situation here.
To put it simply, it is far better to use Inventor to open Inventor files.
If the file you need resides in a folder outside of a current project then use WE to copy that file into the correct project/location ( I don't know why Autodesk can't provide a means to do that for you without having to open up WE???  EG: a simple button that when clicked will copy the file from the current location into the current project's location. )  but that's Autodesk for ya ... :smileyvery-happy:
Anyhow, Good Luck and Happy Inventing.
Regards
Andy M
Distinguished Mentor
ampster
Message 15 of 15 (164 Views)
10-10-2012 06:01 AM in reply to: trumpy81
Not exactly what you mentioned, but you can cut/copy/paste and delete from within Inventor's Open dialog window to move files around.
Good idea on the simple button!
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
