Hello all,
I use a certain matematical function very often when dimensioning a std keyway (kw*kw)/(4*bore)+req'd depth. Would there be anyway to get a shortcut of some type into the dimension box?
tks! =]
Make a parameter and the use the named parameter whenever that equation is needed.
Might just make it an iFeature that you pull in whenever needed.
Hey JD,
I have never done this. Do you have a linky by chance to one of your handy dandy tutorials? 🙂
You could do something like this and use it as a template.
You could also make a Form after to make things easier.
And have something like this one button click away.
I hope this Helps.
JD
