I want to make a change to a material within Inventor 2014. I seem to be able to make the change in a document but I cannot save the change back to the library. I've looked at my project file and it's et to "Use Style Library=Read-Write". I've been able to save dimension styles and parts list styles back to those particular style libraries. Can anyone tell me what I'm doing wrong?
Mark Joyner
Mark,
When you do try to modify your material library, do you have your master project file set to read/write?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
When you say master do you mean the active project file? I'm pretty sure that it's read/write. I've attached a screen shot of the Projects dialog box.
Yes, basically. Have you ever added new/custom material to the material library before and you are just now running into this issues, or is this your first attempt.
It is my first attempt to save modifications of a material back to the styles library. I thought that since I could save dimensional, part list etc. modifications back to their respective styles libraries, that this would be the same. When I click on save I see the materials that I've modified but I only get My Favorites to choose from instead of the Bigge Material Library.
Since you have never done it before, take a look at these threads and see if they help you.
http://forums.autodesk.com/t5/Inventor-General/Add-material-to-custom-library/td-p/3764600
I've attached a couple of screen shots. One is the update style dialog box. You'll see that I can choose to update multiple libraries. The second is the save styles to style library dialog box. You'll see that my only option is Favorites. Why is this my only option?
I checked the file and it was read only. When I remove the read only attribute from the file I still get the same options in Inventor.
This is the whole problem. I should at least be given the option of updating the material libraries from a file as I can update a file from those libraries. If I'm given the option then all I need to do is check the library out of Vault and check it back in.
Vault brings a whole new perspective to this. Since you have it on your local as just a read only, and if this library file is in the vault, do you have admin privelages to the vault? I say this because I am guessing this file is in a location within the vault that only admins can get to. If you are, take ownership of the file and check it out. Make the changes needed then check it back in.
I've already tried that. The problem is that I'm not being given the option to save to the file from within Inventor. I only get the option for Favorites. This is the part that I dont' understand. If I click the update button under the manage tab I get options for all libraries but only Favorites when trying to save back to a library.
A few suggestions to help diagnose where the problem is:
Chris
