Inventor Forum
I2010: Can I create a round sheet metal strap jog between two different straps?
2 REPLIES 2
Passi
807 Views, 2 Replies
Hi there,
in Inventor 2010 we have a sheet metal, with a lot of different straps. But we cannot create round jogs between them. It's only possible, if all straps are created at the same time with the same size etc.
Please see the attached file. The upper version, is the one, it looks in the moment and we want an apperance like the lower one.
Is it possible? Because we cannot add all the round holes later on in development of the sheet metal.
Best Regards
Passi
2 REPLIES 2
Jon.Dean
in reply to: Passi
When you create two adjacent flanges at the same time a Corner Seam is automatically applied.
If you create them using two seperate functions then you need to apply the Corner Seam manually.
Just make sure your "Sheet Metal Defaults" are set correctly.
Jon Dean
Passi
in reply to: Passi
Perfect 🙂
Thx a lot
