Inventor General
Distinguished Contributor
Karol-Or
Message 1 of 3 (95 Views)
How to transfer cuts from assembly
95 Views, 2 Replies
12-04-2012 11:21 AM
I made an assembly and added cuts on parts at the assembly level, but the part files didn't reflect these changes.
How to update those files with the new cuts?
*Expert Elite*
Cadmanto
Message 2 of 3 (82 Views)
Re: How to transfer cuts from assembly
12-04-2012 01:23 PM in reply to: Karol-Or
First is there a reason why these cuts were initially placed in the assembly and not in the part?
Second try editing the part from within the assembly and use the "Project Geometry" command within the sketch environment to choose the assembly cuts.
Then when you open your parts up those cuts will be there.  Then it is up to you if you want to break these external references in the part leading back to the assembly or not.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
*Expert Elite*
Message 3 of 3 (71 Views)
12-04-2012 01:35 PM in reply to: Karol-Or
See if this still works
http://labs.autodesk.com/utilities/featuremanager/
From the ReadMe
"The FeatureMigrator can reliably migrate an assembly feature to the
part level."
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
