Inventor Forum
How to reduce the size of ipt file?
4 REPLIES 4
achmidt
907 Views, 4 Replies
I have a part that almost 9 mb. Pretty simple name plate. Is there any way to make it lighter?
Any help appreciated.
Couldnt even attach it here , so giving you a link below:
IPT FILE
Thank you.
Inventor Virtual Parts Addin
http://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3Avirtualpartsadd-in_windows32and64%3Aen
4 REPLIES 4
karthur1
in reply to: achmidt
Are you trying to make it "lighter" so that you can send it to someone?.....  If so, grab the marker at the end of the part tree and drag it as far up as you can. Then save the part.
If you are on 2013 or 2014, then right click on the EOP marker and choose "Move to Top". When the person gets your file, they will have to move the marker back to the bottom.
achmidt
in reply to: karthur1
yes I knew about this method. But I don`t need to send the file.
Any other suggestions?
Thank you.
JDMather
Can you use a Decal rather than Emboss (at least for most of it)?
The CADWhisperer YouTube Channel
achmidt
in reply to: JDMather
yes, i think you right. Decal will be the best way to make the model lighter.
Thank you.
